What parameters can be used for processing aeroacoustics in a DES CFD simulation ? |
March 22, 2018, 05:19 |
ishan
Rep Power: 9 |
I am going to simulate a 2D aeroacoustics simulation in Fluent using a DES model on a stator. Actually, the simulation should be performed on a complete 3D rotor-stator setup but due to some limitations, I don’t have access to the rotor geometry and computing power. A simplified model of my setup is shown in the attached picture. I have been searching for parameters that I can extract from the DES simulations. These are the following parameters that I can think of: 1)A common parameter is the FFT of pressure data recorded in the wake region of the blade. Using FFT, I want to see if I can see tonal noise peaks or broadband peaks. Based on these observations I can characterize the sound sources such as vortex shedding or just random turbulence. 2) Another parameter that I have come across is the sound pressure which can be calculated by subtracting the instantaneous pressure from the average pressure. How this can be done in Fluent, I am not sure. 3) The other is " divergence of velocity" or dilatation contours. I found it in this article: https://www.researchgate.net/publica..._in_a_Free_Jet I am not able to understand what's the significance of this parameter. 4) Another quantity that can be visualized is the normalized Q-criterion, but this will be good to see the turbulence sources and not aeroacoustics as such. 5) Also, I was wondering if one can actually extract the noise from a pressure signal at a point so that you can hear it. I came across this in the STAR-CCM+‘s user guide some time ago and they say that it can be done. The guide mentioned that that one needs to perform inverse FFT of the signal. Perhaps, people with experience in aeroacoustics can suggest me any additional parameters that can be used. Although the near-field region sound is of interest and not far-field, I am open to using the FW-H model if it provides additional insights. image uploader |
aeroacoustics, des turbulence model, fluent, fourier transform |
Centrifugal fan impeller CFD simulation in OpenFoam | ZachJa | OpenFOAM | 9 | June 15, 2024 12:03 |
Low Y+ vs High Y+ CFD simulation for determining DRAG | surajp92 | Main CFD Forum | 2 | September 19, 2017 04:15 |
Is real time CFD simulation possible | yedla | Main CFD Forum | 5 | March 28, 2016 10:56 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 13:26 |
How to use DES well? | Daniel | Main CFD Forum | 0 | October 26, 2008 06:59 |
