How to set contour values in auto-range in TUI?
Old   March 22, 2018, 01:40
Default How to set contour values in auto-range in TUI?
newbieng is on a distinguished road
Hi guys,
I am working fluent version 18.1 and trying to save contours in png format. However, I could not find how to adjust contour range automatically in text user interface. I activate global-values. I tried the following commands but they did not work.
disp/cont vm () ()
disp/cont vm ( ) ( )
disp/cont vm [] []
disp/cont vm [ ] [ ]
disp/cont vm <> <>
disp/cont vm < > < >
edit: I have already set auto-range by the code (disp/set/cont/ar y) but it is still asking the minimum and maximum ranges!..
newbieng is offline   Reply With Quote
Old   March 22, 2018, 02:13
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
(ti-menu-load-string (format #f "display contour vm \n \n"))
best regards
AlexanderZ is offline   Reply With Quote
Old   March 22, 2018, 03:49
Originally Posted by AlexanderZ View Post
best regards
Thank you for your reply. I cannot run this code in text command window. What is "ti"? Fluent says it is invalid command... The main commands it shows are as the following:
adapt/ file/ solve/
adjoint/ mesh/ surface/
define/ parallel/ views/
display/ plot/
exit report/
Old   April 21, 2018, 03:25
David
uconcorde is on a distinguished road
adapt/ file/ solve/
display/ plot/
exit report/
I am facing the same issue, and wondering if you have got a solution to set auto-ranged contour?
Best,
Dv
uconcorde is offline   Reply With Quote
Old   August 29, 2018, 14:04
Campa
campovski_scott is on a distinguished road
Hi guys,
disp/cont vm () ()
disp/cont vm [] []
disp/cont vm <> <>
my solution is in a journal file file.jou after the command, for example pressure contours, leave two blank lines and then save as image:
display contour pressure
or in console two enters after the command ¨display contour pressure¨
1st blank line or enter to minimum value
2nd blank line or enter to maximun value
(%i = number of iteration)
JPG format is by default
you have to change the picture format to .png to save in this format
file -> Save Picture -> PNG -> Apply
campovski_scott is offline   Reply With Quote
contours, fluent, tui
Storing values for auto generated spacing Bloody_Computer Pointwise & Gridgen 1 July 14, 2016 18:21
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 12:32
Print contour level in TUI Shamoon Jamshed FLUENT 1 August 6, 2009 03:25
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
Reference values set up Plz help! pah FLUENT 0 June 14, 2005 07:39
