How to calculate Turbulent Intensity and Hydraulic Diameter for my problem?
Old   March 19, 2018, 08:33
Default How to calculate Turbulent Intensity and Hydraulic Diameter for my problem?
Roh
Roh is on a distinguished road
Guys,
I'm soppused to solve a problem with this domain. just like this:
I'm using pressure-inlet and pressure-outlet for boundray condition and due to my source, for "Turbulence>Specification Method" I need to set it as "Intensity and Hydraulic Diameter". ok, so far so good. I googled it to know how to calculate them(Intensity and Hydraulic Diameter). For Intensity, found this:
http://www.afs.enea.it/project/neptu...ug/node238.htm
And for Hydraulic Diameter found these:
How to calculate Turbulent Intensity?
hydraulic diameter in 2d
Ok, then for calculating Intensity I need to calculate Reynold's number and for Reynold's number, first off I need to calculate the Hydraulic Diameter. Right? Now the problem is calculating the Hydraulic Diameter. for my two boundary condition I have problem. How should I calculate the Hydraulic Diameter for outlet while the outlet is my domain? And how about the inlet? The inlet area is not a complete circle and it looks like a ring if we look at it at front. Any idea would be appreciated.
Roh is offline   Reply With Quote
Old   June 17, 2018, 04:12
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
It is easy.. just do this:
Dh= 4A/P
Where A is the wetted area and P the premiter of the geometry.
Regard yours
A CFD free user is offline   Reply With Quote
How to calculate Turbulent Intensity? prem FLUENT 10 September 29, 2018 10:46
how to choose the turbulence intensity and hydraulic diameter shlgzz FLUENT 8 March 11, 2013 05:38
Intensity and hydraulic diameter fluentes Main CFD Forum 0 February 1, 2013 13:28
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 12:04
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 11:58
