Getting divergence while increasing the back pressure at pressure outlet
Old   March 19, 2018, 00:39
Default Getting divergence while increasing the back pressure at pressure outlet
greenfields15 is on a distinguished road
I'm trying to simulate 2D- planar over expanded jet in Fluent by enforcing the nozzle exit conditions at the inlet. i.e. setting Total Pressure, static pressure for a particular Mach no and total temperature at pressure inlet and changing the back pressure at pressure outlet. (Not using the c-d nozzle geometry)
I could obtain the perfectly expanded flow correctly, but when i tried to use that solution/data and increase the back pressure, I'm getting divergence..
Divergence detected in AMG solver: temperature
Error at host: floating point exception
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 10901 cells
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error at Node 4: floating point exception
Error at Node 5: floating point exception
Error: floating point exception
Error Object: #f
Parameters for M=3.17 at inlet
Operating Pressure = 0 Pa
1. Perfectly expanded jet:
Pressure inlet
Gauge Total Pressure:5000000 Pa
Initial Gauge pressure: 104965 Pa
Total Temperature: 300K
All Pressure outlets
Back flow Total Temperature: 300K
2. Over expanded jet
Pressure inlet
Static pressure: 104965 Pa
All Pressure outlets:
Gauge pressure: 390000 Pa
Could you please give some suggestions to overcome this issue? My requirement is to increase the back pressure to reach 3rd critical condition, then reduce the back pressure to reach back to perfectly expanded state.
Thank you.
greenfields15 is offline   Reply With Quote
back pressure, divergence amg solver, fluent
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
pressure outlet back flow Danial1992 FLUENT 1 May 3, 2017 06:52
the static pressure at one outlet is negative? yuhehuan Main CFD Forum 7 August 15, 2013 22:01
Question Concerning Pressure Value (Pressure outlet) and Reference Pressure (Physics) andy_flow STAR-CCM+ 1 July 9, 2013 09:44
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
