March 16, 2018, 12:01 |
Supersonic Flow over a Cone
Phurit Pookayaporn
Hi all,
I have been studying on using Ansys Fluent from SimCafe class (on Confluence site; https://confluence.cornell.edu/displ...ge+-+Exercises) I had done this to analyze supersonic flow over a wedge (with the setting of 2D and symmetry (the name of the bottom horizontal line) as a symmetry type in the boundary condition setup. Now, i used the same meshing but changing the problem setup (in the 2D space) as axisymmetric and the symmetry line as the type of axis. The problem is the results were not as i expected and can be seen in the website. So could anyone tell me what i might have been doing wrong? Apologize if this disrupt anything Thank you in advance |
#cone, #supersonicflow |
How is the accuracy using VOF (pressure based solver) on supersonic flow | air_fun | Fluent Multiphase | 1 | August 25, 2021 00:59 |
Velocity Profile for flow over circular cone | rameshbhoraniya | FLUENT | 3 | March 30, 2016 02:11 |
[How to obtain supersonic flow inside a supersonic wind tunnel ?] | yx213 | Siemens | 1 | September 17, 2014 13:52 |
In compressible flow over a Circular cone | rameshbhoraniya | Main CFD Forum | 0 | September 9, 2013 03:02 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
