Finding amount of particles that hit the surface of the object inside the flow path |
anonymous
Rep Power: 0 ![]() |
I have simulated the air particles (oxygen) which flow through the channel by using ANSYS.
There is a disk-shaped object in the channel as shown in the picture. I want to know amount (or percentage) of air particles that hit the surface of the disk-shaped object. Is it possible to know it using ANSYS? Thank you in advanced 1.jpg 2.jpg |
air flow simulation, ansys 18.2 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 07:11 |
problems with tight flow domain on object | jemteo | CFX | 0 | August 3, 2004 06:17 |
Determine mass flow rate along flow path | Atit Koonsrisuk | CFX | 2 | October 5, 2003 04:47 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
