Joshua Smith
Rep Power: 8 ![]() |
Here is a simplified description of the original problem.
I have a tank of two fluids (for example water and air). I am looking at the sloshing of the fluids as the tank is pitched upward. This sloshing will shift the center of mass since the two fluids have different densities. I am interested in writing the center of mass of the volume as a function of time. I know that the center of mass (for example for x) is determined by the triple integral of x*density with the integral divided by the total mass (http://www.math.wpi.edu/Course_Mater...abs/node3.html). I also know you can take the volume integral of density. I think the center of pressure calculation would only work in specific cases (no pitch). Is there a built in function, or a way to take the volume integral of a custom function, that would give the center of mass of the fluid and output it as a monitor? Thank you. Joshua |
Emily
Did you ever find a solution to this problem? I'm trying to make a similar simulation which will output the center of mass, but have yet to figure out how to do that.
center of gravity, center of mass, two-phase flow |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 17, 2003 19:23 |
How to obtain mass flow rate of one phase | Derek Jing | FLUENT | 1 | May 31, 2002 13:18 |
mass flow rate of a dispersion phase | Paul | FLUENT | 1 | February 25, 2002 23:19 |
