RP_variable from UDF: unable to find rpvar
Old   March 14, 2018, 13:13
Default RP_variable from UDF: unable to find rpvar
DS
denis.sanga@hotmail.it is on a distinguished road
Goodmorning,
I'm sorry for disturb but I've a problem to read rp_variable list in my UDF (ADJUST function).
In particular I initialize the following scheme:
(define (make-new-rpvar name default type)
(if (not (rp-var-object name))
(rp-var-define name default type #f)))
(make-new-rpvar 'a '() 'list)
(rpsetvar 'a ())
(for-each (lambda (t) (rpsetvar 'a (list-add (rpgetvar 'a) (thread-id t)))) (get-all-threads))
(rpgetvar 'a)
(make-new-rpvar  'b '() 'list)
(rpsetvar 'b ())
(rpsetvar 'b (list-add(rpgetvar 'b) "fluid-1 fluid-2"))
(rpgetvar 'b)
and in the UDF the following extract of code:
int l_a= RP_Get_List_Length("a");
printf("l_a=%d\n",l_a);
int r_a=RP_Get_List_Ref_Int("a",1);
printf("a=%d\n",r_a);
int l_b= RP_Get_List_Length("b");
printf("lunghezza_b=%d\n",l_b);
char* r_b=RP_Get_List_Ref_String("b",1);
printf("b=%s\n",r_b);
but always appear errors as follow:
6: unable to find rpvar 'a'
3: unable to find rpvar 'b'
or
7: RP_Get_List_Length: Unable to get length of a.l_a=-1:
But when in the console I write
(rpgetvar 'a) the vector of integer or strings is printed.
Can someone help me please.
Thank you very much
Best regards
Denis
denis.sanga@hotmail.it is offline   Reply With Quote
Old   March 14, 2018, 22:16
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I've tried to compile our code and got these erros:
..\..\src\temp.c(7) : error C2143: syntax error : missing ';' before 'type'
..\..\src\temp.c(8) : error C2065: 'r_a' : undeclared identifier
..\..\src\temp.c(9) : error C2143: syntax error : missing ';' before 'type'
..\..\src\temp.c(10) : error C2065: 'l_b' : undeclared identifier
..\..\src\temp.c(11) : error C2143: syntax error : missing ';' before 'type'
..\..\src\temp.c(12) : error C2065: 'r_b' : undeclared identifier
You may use this code
#include "udf.h"
DEFINE_ADJUST(temp_adjust, d)
int l_a,r_a,l_b;
char* r_b;
l_a = RP_Get_List_Length("a");
Message("l_a=%d\n",l_a);
r_a=RP_Get_List_Ref_Int("a",0);
Message("a=%d\n",r_a);
Message("lunghezza_b=%d\n",l_b);
Message("b=%s\n",r_b);
DEFINE_ON_DEMAND(temp_demand)
int l_a,r_a,l_b;
char* r_b;
However, our variable b is defined the way, I didn't expect.
Looks like you have a list with only one element, but that element is a list of "fluid-1 fluid-2"
But you expect to have a list with two elements "fluid-1" "fluid-2"
You need to fix it in scheme, before using
This is what I got in console
> (list-ref (rpgetvar 'b) 1)
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
> (list-ref (rpgetvar 'b) 0)
fluid-1 fluid-2
best regards
AlexanderZ is offline   Reply With Quote
Old   March 16, 2018, 06:32
Default differences between C_P and F_P
DS
Thank you really much for your answer. Now the code works but I desire to add another question.
I would read the pressure on some walls and boundary and I post following the part of the code with which I do that in two different ways as I found online using C_P and F_P:
thread_loop_f(t,d)
begin_f_loop(f,t)
c0=F_C0(f,t);
t0=THREAD_T0(t);
C_UDMI(c0,t0,0)=C_P(c0,t0);
F_UDMI(f,t,0)=F_P(f,t)
end_f_loop(f,t)
While on the walls the value C_P(c0,t0) are the same on the inlet boundy or outlet the two quantities are different but I don't understand why (maybe for interpolation calculations).
For this reason if I interested to store the static pressure is better to write
or
C_UDMI(c0,t0,0)=F_P(f,t)
Another question is on F_UDMI memory. I understood that C_UDMI and F_UDMI are different and they don't comunicate each other. But I don't understand how to postprocess F_UDMI quantities in Fluent or Tecplot.
Thank you really really much
Best Regards
Denis
udf rp variables
mpirun unable to find SU2_PRT Apollinaris SU2 Installation 1 May 10, 2017 06:31
Unable to find solver in Compressible case rhoDyMCentralFoam openFOAM 2.3.1 Version amolkumar OpenFOAM 0 March 3, 2015 06:27
Unable to find solver sonicDyMFoam in OpenFoam2.3.1 ashisha OpenFOAM 0 March 3, 2015 06:00
Help! where to find full UDF Macros and functions kim FLUENT 6 March 5, 2014 10:01
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
