Naresh Mahendran
Rep Power: 8 ![]() |
Hi all,
I'm using Macro method to solve the heat exchanger ( intercooler ). All the inputs that are needed for the ungrouped macro model is given and is made to solve. It gets solved within 100-500 iterations and the solution is converged and I'm getting the correct temperature value and all. But when I open in contours, I can see that only 30-40% of the model is solved and the remaining portion left unsolved. So I unticked the "check convergence" option from the "Monitor" tab. And then I made it run. Now it has run nearly 70000 iterations and still the contours looks the same. Please help me to solve it. Thanks in advance. |
Cees Haringa
Rep Power: 0 ![]() |
how do you mean "looks unsolved"? Can you be a bit more clear on what you observe?
Alexander
Rep Power: 34 ![]() ![]() |
into contour options use "Filled" and "auto range". Choose proper surfaces.
may be this will help you. best regards |
contours, convergence, heat exchanger, not solving |
UDF for fully developed turbulent flow at inlet | soroushsaberi | FLUENT | 0 | May 28, 2014 18:00 |
UDF for 3D turbulent fully developed flow | howhs | Fluent UDF and Scheme Programming | 0 | August 1, 2013 12:47 |
How to introduce my desired fully developed Boundary Condition? | Milad06 | OpenFOAM Running, Solving & CFD | 0 | July 8, 2013 05:54 |
Fully developed temperature profile in OF !!! | Goutam | OpenFOAM Running, Solving & CFD | 0 | July 5, 2012 08:44 |
inlet velocity profile for fully developed turbule | pankaj saha | Main CFD Forum | 4 | August 24, 2007 17:53 |
