Problem with pressure delta in internal walls |
March 9, 2018, 13:47 |
Mauro
Rep Power: 8 |
Hello friends, I have a problem with one of my simulations, I've just start working in a company and I'm new in Fluent.
I'm using Fluent V18.0. I have a single phase, 3D model, the geometry is a tank, with a lateral inlet and a upper outle, inside the tank there is a plate, transversal to the water flow, that has windows where the water pass through. I've modelled the plate as surface and with a "wall" boundary condition. The software has create the shadow of this surface...so I suppose that use the real surface as one side and the shadow as the other side of the plate. I've finished the simulation and here is the problem, I need to determine the difference of pressure (between the original surface and the shadow) to do the mechanical design of this plate. I can make a pressure contour in the surface and in his shadow (the pressure distribution are differents, and this is ok) but I could not obtain the difference of pressure in the surface. Thank you very much for your answer. Mauro. |
March 9, 2018, 18:39 |
#2 | |
Lucky
Rep Power: 66 |
In your case I'm not sure what Fluent did since you don't have a solid. |
deltap, internal wall, post procesing, pressure |
Smoothing of IDDES delta | Fuchs | OpenFOAM Running, Solving & CFD | 2 | November 17, 2020 12:17 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 17:36 |
[Gmsh] Generating multiple internal walls using gmshToFoam | rendagar | OpenFOAM Meshing & Mesh Conversion | 2 | October 20, 2014 04:56 |
Low pressure de Laval simulation convergence problem | heksel8i | FLUENT | 3 | July 22, 2013 11:28 |
Operating Pressure (Natural Convection problem) | Andrew Tress | Main CFD Forum | 1 | July 3, 2006 17:00 |
