Naresh Mahendran
Rep Power: 8 ![]() |
I'm doing my thesis on radiator through porous method.
I have calculated the viscous and inertial resistance. But there is space for entering porosity. Should I enter the calculated porosity value or should I leave it as 1 ? Help me. Thanks in advance |
Kushal Puri
Rep Power: 12 ![]() |
If you are doing just flow analysis then no need to apply the porosity value, but if you are doing heat transfer then you have to give the value of porosity as well as you have to define the material also there.
#3 | |
Naresh Mahendran
I'm doing heat transfer analysis on radiator. The calculated value of porosity is 0.5 So should I give this value as porosity ? |
Kushal Puri
Yes, you have to define porosity value of 0.5 and in the same window you have to apply the material also for heat transfer
#5 | |
Naresh Mahendran
Coolant in Temp is 363 K Required coolant out temp is 353 K But I'm getting 361.8 K There is only 1 K drop in the radiator tube. All the inout BC are correct. Do you have any reason for this ?? |
#6 | |
Kushal Puri
#7 | |
Naresh Mahendran
I have another doubt. Do you know the exact procedure to find out the inertial and viscous resistance ? I know the formula for inertial and viscous resistance. Rv = [(150 (1-porosity)^2) / (sphericity^2 . Dhyraulic Dia^2 . porosity^3)] Ri = [(3.5 (1-porosity)) / (sphericity . Dhyraulic Dia . porosity^3)] How to calculate the sphericity value and what will be the value if it is rectangle and my dimensions are 2.83*0.08*49 mm Thanks in advance. |
#8 | |
Kushal Puri
#9 | |
Naresh Mahendran
I'm simulating the entire cooling system ( radiator, CAC, Condenser ). I simulated and have the results of each individual part. Now I need to simulate it together by giving a single air velocity. I thought to do it with Macro model method due to computational resources. I even tried each part individually in Ungrouped Macro Model and got the results correctly. Now I need to run it together. But I dont know how to do it? Should I use grouped or ungrouped macro model and how to do it ? Please help in simulating it. Thanks in advance. |
ansys, fluent, porosity, radiator |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Porosity profile, dividing a zone, or getting zone location from zone | khoopes | FLUENT | 0 | June 2, 2012 19:39 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
