How to import material parameters from Excels in Fluent? |
March 5, 2018, 00:57 |
lixinjun
Rep Power: 13 |
Hi everyone!
My objective is read some temperature-pressure dependent parameters to Fluent from some Excels in every iteration. I have three Excels (“parameter_1.xlsx”, “parameter_2.xlsx” and “parameter_3.xlsx”) to describe these temperature-pressure dependent parameters. Each Excel file have the "T", "P" and "parameter_n". The excel date format is like, T 10 20 30 40 50 … P 0.1 0.2 0.3 0.4 0.5 10 0.1 0.4 0.2 0.2 0.8 20 0.3 0.2 0.5 0.2 0.9 30 0.5 0.2 0.1 0.1 0.2 40 0.7 0.2 0.8 0.3 0.4 50 0.1 0.2 0.2 0.6 0.2 … In every iteration, I need to read these 3 parameters for each node by interpolation, based on excels. Do anyone know a simple way to solve this problem? I am waiting for an answer. Thank you very much! |
September 12, 2020, 07:52 |
Property Variation of Supercritical Flow
#2 | |
Thamilmani M
Rep Power: 9 |
Hi, Have you found answer to this question?
Always Thedal |
fluent |
How to import a data file (excel,txt or csv)to Fluent or CFD-Post? | silvai | ANSYS | 16 | January 31, 2020 05:52 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
How to import a data file (excel,txt or csv)to Fluent or CFD-Post (the easiest one)? | silvai | FLUENT | 0 | January 5, 2015 10:22 |
Import Soliworks geometry to Ansys Fluent 12.0 | nunolopes | FLUENT | 0 | October 7, 2010 12:24 |
