John Smith
Rep Power: 8 ![]() |
I'm having trouble with getting my journal file to run on a linux machine (HPC). The file runs perfectly on a Windows 10 platform. Both are running Ansys 18.2 and Fluent 18. Simple journal file commands attached. Transient simulation. It fails at two lines 1) /solve/initialize/hyb-initialization 2) /solve/dual-time-iterate 10 21 The dual-time-iterate command produces this error, but only on a linux version. /solve/dual-time-iterate 10 invalid command [10] Any ideas on why, or a possible workaround? Cheers |
John Smith
Problem Solved! Use the batch command -gu, not -g as it seems fluent requires graphics to run hyb-initialization and dual-time-iterate
Ekha
Rep Power: 7 ![]() |
I am facing the same errors, could you please explain how you solved this issue. How to use -gu command ? Thanks Esra |
John Smith
Hi Esra,
Here's a (stripped) example of my batch file with the commands I used. I was running on a cluster. Just put the commands similar to testingfluent.txt in your journal file. #!/bin/bash # #PBS commands go here set echo on hostname # Load the ansys module module load ansys/18.2 # Move to the directory where the job was submitted from # Create the config file for socket communication library cd $PBS_O_WORKDIR rm -f pnodes cat $PBS_NODEFILE | sort > pnodes export ncups=`cat pnodes |wc -l` version=2ddp # Run Fluent fluent $version -t$npus -cnf=$PBS_NODEFILE -gu -i journalfile.jou > output_file |
#5 | |
Cheers Halil |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
