CFD Newbie, Modeling Flow in a Split Pipe
Old   February 23, 2018, 14:19
Default CFD Newbie, Modeling Flow in a Split Pipe
TheReckoner's Avatar
H. M.
TheReckoner is on a distinguished road
Hello, I am trying to model flow in a split pipe. This is this shape
---<--- and it has 3 inlets to 1 outlet. In the simulation, I would like to examine the mixing patterns (likely with flow trajectories), as well as shear forces. I have several questions. How should I approach this in general?
I have imported the geometry from SolidWorks, and the model's pipes are hollow. Should the model be filled? I was watching this tutorial which is somewhat similar to what I am doing, and the part is completely filled, so it appears. Do I just need to plug the ends of my pipes?
https://confluence.cornell.edu/displ...+Artery+-+Mesh
I have calculated Reynolds Numbers at several speeds and the flow is turbulent. How should I go about incorporating this into my simulation. Will fluent know that the flow is turbulent?
How should I go about generating the mesh? Should I just go with the mesh that fluent already generates?
Let me know if you have any more questions for me. Sorry, I am very new to CFD! Thank you.
TheReckoner is offline   Reply With Quote
fluent, split pipe
how to modeling evapourating in pipe flow? Joey Fluent Multiphase 26 March 18, 2015 01:30
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 01:30
Need help in Modeling of oil-water flow in A vertical Pipe Shikha10 Main CFD Forum 0 April 1, 2013 10:33
CFD Analysis of 2D Turbulent Pipe Flow erucalavera FLUENT 1 May 30, 2012 06:22
ys/R term in pipe flow: cfd validation husker Main CFD Forum 0 May 8, 2012 10:29
