how can I measure volume of a particular droplet?
Old   February 21, 2018, 06:15
Default how can I measure volume of a particular droplet?
ALI
ars511 is on a distinguished road
I'm using VOF model to generate droplets. I want to measure the volume of generated droplet. Is there any way to do this?
ars511 is offline   Reply With Quote
Old   February 21, 2018, 18:54
Lucky
For a particular droplet this is not possible (at least not easily). If you could tag the droplets then a simple volume integration will give you the droplet volume. The problem is there's no tracking or tagging to distinguish droplets.
droplet volume, vof
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 04:23
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
