Moving ball in tube
Old   February 20, 2018, 16:47
Default Moving ball in tube
xatzi is on a distinguished road
I am trying to simulate the movement of a ball in a tube because of the fluid flow inside said tube. I have trouble using the moving mesh option with the 6DoF solver as the ball that i created only reacts to the gravity and it does not bounce of the wall of the tube as it should. Any ideas of what i am doing wrong? Any help would be greatly appreciated.
Thank you in advance.
xatzi is offline   Reply With Quote
Old   February 21, 2018, 00:39
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
It is not trivial. You can set the physics yourself through udf for that to happen.
Far is offline   Reply With Quote
moving mesh body forces
Problems moving a ball - mesh crashes lbergmann CFX 24 February 16, 2016 09:01
How do simulate ball moving in water vidq09 CFX 4 June 5, 2015 06:00
Strategy for a projectile moving inside a tube kiwa21 Main CFD Forum 0 March 7, 2013 15:49
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
ICEM block mesh with a ball in a cylinder tube Li CFX 6 August 11, 2008 06:44
