Temperature increas inside turbine
Old   February 18, 2018, 16:30
Question Temperature increas inside turbine
ram_call's Avatar
ram
ram_call is on a distinguished road
hello all,
I have simulated a kind of turbine using sliding mesh, ideal gas (air)
inlet: pressure inlet
outlet: pressure outlet
as you can see, the temperature in the gap (which is 0.1 mm gap between vanes and casing), goes higher than inlet!!! (inlet is 400K)
Does anyone have any idea why energy equation is solving like this?
please find the temperature contour attached
ram_call is offline   Reply With Quote
Old   February 19, 2018, 21:14
ram_call's Avatar
ram
Any kind of comment would be appreciated. this is going to become a crazy problem for me
energy equation, ideal gas, sliding mesh, turbine
CFX SCO2 turbine temperature Cafard CFX 3 August 6, 2014 12:02
wind turbine simulation inside the wind tunnel shaohua FLUENT 4 April 11, 2014 18:01
Temperature BC inside a phase shashank312 Fluent UDF and Scheme Programming 0 May 29, 2013 17:54
How to set report type when monitor gas temperature inside cylinder? ellen FLUENT 0 July 13, 2012 04:50
[Help!] UDF:DPM-Particle inside temperature profile Ryan_Yang Fluent UDF and Scheme Programming 0 May 4, 2012 11:00
