February 18, 2018, 15:01 |
VOF Implicit formulation divergence issue
Hamed Abdul Majeed
Rep Power: 14 |
Hi
I am using an implicit formulation to solve a VOF problem. My goal is to compare the explicit and implicit VOF schemes. I get good results using explicit formulation. When, I used the 1st order time discretization of the implicit scheme I don't get good results. In the Fluent manual, it says that implicit schemes has accumulation of turncation errors that is why use higher order discretization. My question: When I use 2nd order time discretization in the implicit scheme I get divergence in the pressure correction eq. Any body encountered a similar issue...or could help? Thank you. |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
Two Phase Flow In Vertical Pipe | stonepreston | FLUENT | 2 | October 31, 2017 09:35 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 07:58 |
problem about VOF and species couple | Cloud | FLUENT | 0 | June 15, 2012 02:23 |
Moving mesh or VOF? | Giovanni | Main CFD Forum | 16 | September 24, 2001 09:25 |
