Melting of Ice
Old   February 16, 2018, 13:31
Default Melting of Ice
Abdul
arehman1289 is on a distinguished road
Im using the solidification/melting model to simply melt ice in a container. I have a 1mm thick copper container at a constant temperature of 1500 K. It is completely filled with water liquid initially patched at 250K. I then run a transient simulation but dont get proper results.
1. When I select the VOF model, I even get two phases for my solid copper container, although I dont need that. I just need one phase on this material and two phases of water. I also fixed the liquidus and solidus temperature to 273.15 of water. Is there any guideline on how to use the VOF in conjunction with the Solidification/Melting model ? Most of the Fluent booklet guide is not helping. I used YouTube simulations till now.
2. I want to observe the temperature vs time plot of a single point in the water and want to view the horizontal temperature phase change line to ensure the phase is actually changing. However when I select a point to monitor, I can either select a surface or area, weighted averages. This gives me a linear graph and I am unable to really see the phase change.
Looking forward to your reply.
Thanks
Abdur
arehman1289 is offline   Reply With Quote
Realisation of density for melting process of ice spalartallmaras Fluent Multiphase 0 January 5, 2018 03:27
Multiphase Ice slurry with melting model mohibanwar Fluent Multiphase 0 March 5, 2016 02:43
pure melting of ice due to water at higher temp ABH Fluent Multiphase 0 April 2, 2014 07:00
ice melting simulation pratikmehta ANSYS 3 April 17, 2013 10:52
Ice melting Simulation pratikmehta CFX 13 February 29, 2012 22:14
