Jarek Kolodziej
Rep Power: 0 ![]() |
hi
i simulate the folw of water in a large tank (cylinder). Model is 2d, axisymetric. The tank have one input(velocity-inlet) and one output (negative velocity-inlet). At the beginning the tank is filled with water (313K) to a certain level (picture), then at the inlet we have water at 371 K and at the outlet is water of the same mass. The mass of water in tank does not change. I have problem because in 2d simulation i can't define mass flow. I must have the same flow mass in inlet and outlet. When i define the same velocity the mass of water in tank is change, because i set the density of water a polynomial. Can i set the velocity at the outlet depending on the velocity at the inlet? https://i.imgur.com/WJptdVB.png |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 14:27 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Problem with porous flow at multi-material interface with large permeability diff. | Hisham | OpenFOAM Programming & Development | 1 | June 3, 2016 10:51 |
2D, VOF, AIR and WATER flow, around circle, what's wrong ? | undziabundzia | FLUENT | 4 | November 13, 2015 19:00 |
[ICEM] Mesh strategy large tank | DoubleG | ANSYS Meshing & Geometry | 2 | January 10, 2013 10:15 |
