calculating first layer wall thickness
Old   February 15, 2018, 15:38
Default calculating first layer wall thickness
Tyler Richardson
tricha122 is on a distinguished road
I am trying to calculate y* during the fluent solution within a UDF. From what I can tell from the available cell / face variables, I can retrieve the turbulent kinetic energy (Kp), and then using this and the cell center height (Yp) I can calculate y*.
turbulent kinetic energy can be retrieved with F_K(f,tf)
How can I retrieve the height of the cell adjacent to the wall? certainly this has to be available as it uses it to evaluate the wall function
Any help would be greatly appreciated!
Thanks!
tricha122 is offline   Reply With Quote
Old   February 15, 2018, 15:57
Lucky
What version of Fluent are you using????? Depending on the version you might be able to use:
C_WALL_DIST
Calc_Cell_Wall_Distance_New
Calc_Cell_Wall_Distance_Alternative
Check out this thread:
Old   February 15, 2018, 16:09
Tyler Richardson
I am using Fluent 18.2
is there documentation for C_WALL_DIST?
otherwise I guess I could get the centroid of the face, centroid of the cell, and get the length of the vector between them
scheming, wall function, y plus, y star
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] Meshing a very thin meatus with SnappyHexMesh enginpower OpenFOAM Meshing & Mesh Conversion 29 September 9, 2017 04:46
Radiation interface hinca CFX 15 January 26, 2014 18:11
Boundary Layer roughness/ low reynolds wall treatment Luigi_ STAR-CCM+ 1 March 14, 2012 09:40
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
