Wake Behind Oscillating Airfoil_No Vortices
Old   February 11, 2018, 14:10
Default Wake Behind Oscillating Airfoil_No Vortices
frantsesko
fra_kts is on a distinguished road
Hallo my friends ,
I am trying to simulate, in Fluent 15.0 , an oscillating airfoil, in 2D, with the following characteristics :
1)NACA 64418
2)heaving amplitude =0.05 m
3)pitching amplitude =4 degrees
4)air inlet speed =26.4 m/s (Re=0.85 * 10^6)
5)chord =0.5
6)pivot point =chord/3 (from leading edge)
7)heaving eq. of motion :h=0.05*sin(2*pi*t)
8)pitching eq. : a=1+4*sin(2*pi*t)
9)time step = 0.001 s
The turbulence model i am using is the Realizable k-e .
In order to simulate the pitch and heave motion i use sliding mesh, which is attached to the airfoil , which moves also vertically (with magnitude of motion 0.05 m) .
Mesh characteristics :
1)y+=1
2)1878 elements on airfoil
3)inflation with 30 layers and growth rate 1.2
4)170.000 elements in total
The problem i am having is that in the velocity curl contours i cant see any vortices . (see attachment)
Should there be any at this amplitudes of oscillating motion and velocity ?
In the picture you can see the velocity curl field every 0.25T of the motion .
Thank you very much in advance .
fra_kts is offline   Reply With Quote
Old   February 14, 2018, 08:16
frantsesko
Any Help ?
airfoil 2d, fluent, oscillating airfoil, vortices, wake
Hairpin vortices in turbulent channel flow using DNS Nitin Minocha Main CFD Forum 2 November 21, 2016 18:52
having problems with implementing the wake rollup for a panel method smilesgiles89 Main CFD Forum 0 August 6, 2015 21:09
Initializing trailing vortices in fluent zakir FLUENT 1 February 16, 2014 08:54
Wake Vortices dimitris340 FLUENT 0 May 1, 2010 05:59
Cylinder Wake calculation Adam Chapman Main CFD Forum 1 January 30, 2007 13:54
