February 8, 2018, 13:43 |
Save output of udf in another udf!
I have a compiled udf fluent, this udf read some parameters and then you can define a energy and mass source with the udf profile. I will like to define different sources with different parameters with the same udf. There is a way for saving the output of the udf in another udf or save the profile of the source? p.d. I canīt modify the primarily udf, i donīt have the source file. Thanks in advance! |
profile, sources, udf |
Need help in writing UDF for an oscillating airfoil to get Output parameters | ned.musab | FLUENT | 0 | October 27, 2017 12:21 |
UDF for output temperature | mariam.sara | Fluent UDF and Scheme Programming | 9 | August 19, 2017 09:22 |
udf problem.. output data comes out to "zero" | startup0820 | Fluent UDF and Scheme Programming | 3 | August 16, 2012 00:09 |
save data output at specific point using probe | foam_noob | OpenFOAM | 0 | March 11, 2010 03:13 |
How to save macro results in the output file? | Peggy | FLUENT | 0 | May 21, 2007 04:36 |
