February 4, 2018, 15:09 |
High Pressure Gradient and Velocities
Hells Blade
Rep Power: 8 |
Hi
Does anyone have experience dealing with high pressure gradient and velocity gradients. Attached is my contour results- velocity and mach no I have a 90 mm dia by 300 height cylindrical air blower as inlet at the top The air is blown through a 300*300 mm domain wall thickness 2 mm These are two seperate bodies (formed one part - no boolean ) I have ultrasonics velocities at my oultet when the pressure at inlet is 6 bar Solver Settings Coupled K epsilon realizable ideal gas - material Ultrasonic speeds at bar pressure is it possible ? Or do i need to select a finer mesh grip and different solver settings for higher pressure gradients Last edited by hellsblade.91; February 4, 2018 at 17:33. |
mesh 3d, pressure and velocity, solver convergence, turbulence analysis |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 16:36 |
Two fundamental questions about icoFoam while updating the velocities and pressure | dbxmcf | OpenFOAM Running, Solving & CFD | 6 | April 12, 2016 16:05 |
Rotating Reference Frame Pressure Gradient | clac | FLUENT | 0 | August 22, 2012 18:20 |
pressure gradient plot | Angeline | FLUENT | 0 | November 26, 2010 01:16 |
Too high pressure gradient in an emptying case | Alireza | FLUENT | 0 | November 6, 2005 02:59 |
