Will refining the grid help in better convergence? |
February 4, 2018, 10:36 |
Noel
Rep Power: 9 |
My 3D mesh with K-omega simulation of a fan has a pretty good quality, with just a few cells out of 0.8 million with an orthogonal skewness >0.7. However, the residuals are stagnating at just about 10e-3 for velocities and 10e-2 for continuity.
Any suggestions? |
February 5, 2018, 08:59 |
Kirill Borodin
Rep Power: 10 |
Hello! Please show the mesh and tell which boundary conditions do you use. Which y+ value did you try to obtain?
February 5, 2018, 12:40 |
Gert-Jan
Rep Power: 28 |
Which k-omega model?
And settings? |
February 5, 2018, 15:51 |
Kirill Borodin
Rep Power: 10 |
I mean pressure, temperature and velocity/Mach number in the inlet
April 11, 2018, 01:09 |
Sorry for the later reply. Didn't get notified. How does Fuent calculate residuals?
Noel
Rep Power: 9 |
Hi Kirill and Gert,
Sorry for the later reply. I didn't use y+ for first layer thickness. I used AR of 10 for k-omega (standard). I'm simulation an axial fan with MRF. 1st inflation layer AR=10 on all walls. Only pressure outlets. With an RPM of 2500. I worked on max orthogonal skewness and brought it down to 0.7. I've get my residuals to 10e-4 and the parameters of total-pressure and heat-flux are not changing. Hence, I've taken them to have converged. But I just wanted insight into how Fluent actually calculates residuals. Thanks! Kind regards, Noel |
convergence, fan, refinement, residuals |
Grid Convergence Study | Hybrid | Pointwise & Gridgen | 5 | April 18, 2016 10:40 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Re: Convergence problem for refined grid | CFD_Novice | Main CFD Forum | 13 | February 17, 2008 23:56 |
Convergence on non-uniform grid | dragon | Main CFD Forum | 2 | January 31, 2005 03:23 |
