DO Model radiation fluent (Semi-transparent) problem
Old   January 29, 2018, 12:21
Question DO Model radiation fluent (Semi-transparent) problem
Mostafa
sasa mohamed is on a distinguished road
I am using DO model in fluent to simulate 3D double glass layers and the water flows between them. The solar irradiance applied at the first glass layer at 800 w/m2 and this value was divided between three wavelength bands, (1) from 280 nm to 400 nm with (40 w/m2), (2) from 400 nm to 700 nm with (344 w/m2) and (3) from 700 nm to 2000 nm with (416 w/m2). Both the absorption coefficient and refractive index of water and glass are varying with each band. the top surface of first glass pattern is defined as semi-transparent surface and the direct irradiance was applied as mentioned before (boundary condition).
During the calculation of fluent, the residual of DO intensity equation does not converge more than 2e-4. After 500 iterations, the do intensity equation still constant. After the calculation process finished (3000 iterations), I checked the radiation heat flux (from wall fluxes).
I found that there is no any irradiance transmit to the top surface of the water which interfaces directly with the bottom surface of the first glass layer, Secondly, the backside of first glass layer has negative values of radiation heat flux. Although, the energy equation converged until 1e-13, as well as the temperatures of all walls, are very reasonable and logical.
Actually, I tried with all ways to tackle this problem but I didn't find any solution. But when I increased the direct irradiance value to 20000 (w/m2) (not logic), the solar radiation transmits to the water.
if anyone has a solution or suggestion to overcome this problem, please don't hesitate to help me. Thanks in advance
regards,
mostafa
sasa mohamed is offline   Reply With Quote
Old   February 20, 2018, 05:35
Petar Filipovic
Petar Filipovic is on a distinguished road
Hi Mostafa,
Did you manage to solve your problem?
I am using DO model with semi-transparent BC to simulate heat transfer inside solar collector. So far I discovered that defining material properties of solid (glass in my case) has the biggest impact on the result. I have observed some strange radiation fluxes (surface incident radiation, transmitted radiation etc.) which strongly depend on the refractive index of a material.
In the enclosure, I send you my excel file with wall flux reports in my case.
Best regards, Petar
Petar Filipovic is offline   Reply With Quote
Old   February 20, 2018, 10:20
Mostafa
Originally Posted by Petar Filipovic View Post
Hi Mostafa,
Best regards, Petar
Dear Petar,
really, i have solved my problem through different procedures. Firstly, for the mesh interfaces, you should convert all mesh interfaces setting into the coupled wall (thermally coupled) and avoid the overlapping in contacts regions.
Secondly, if your incident solar beam is normal to the glass surface, you can set the glass refractive index @ 1. (for the non-gray model).
Thirdly, in order to check the incident radiation heat flux on surfaces, Surface integrals >>>> Area-Weighted Average >>>> Heat Fluxes >>>> Radiation Heat Flux. (if you find its value in negative sign that means the radiation heat flux leaves the surface).
Best regards,
Mostafa
Old   February 20, 2018, 10:31
Petar Filipovic
Dear Mostafa,
Thank you for your answer!
Can you specify why refractive index can be set at 1 if my beam is normal to the glass surface?
Best regards, Petar
Old   February 20, 2018, 11:31
Mostafa
Dear Mostafa,
Best regards, Petar
Dear Petar,
When I reviewed the relations to other quantities part regarding refractive index in the following link, I have concluded that.
[URL="http://en.wikipedia.org/wiki/Refractive_index"]https://en.wikipedia.org/wiki/Refractive_index
Best regards,
Mostafa
Old   August 2, 2019, 08:01
MohaddeseMh is on a distinguished road
Originally Posted by sasa mohamed View Post
regards,
mostafa
Dear Mostafa,
I'm using DO model in fluent, the solar radiation is about 740 w/m^2 and I don't know how to divide this value between 5 wavelength bands (like from 200 to 400 nm - 400 to 600 nm and ...) .
Did you use any formula or plot?
I would really appreciate it if you could help me with that.
Sincerely
Mohaddese
MohaddeseMh is offline   Reply With Quote
Old   October 2, 2023, 09:47
bkm
Bk
bkm is on a distinguished road
I want to do CFD analysis of solar flate plate collector how to set my problem in 2D analysis in ansys fluent....top glass middle air bottom absorber plate... should I go with DO model or Heat flux apply on plate
bkm is offline   Reply With Quote
Fluent Radiation Problem entropies FLUENT 5 November 28, 2022 17:04
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
