Initialize flow from different geometry
Old   January 24, 2018, 05:43
Question Initialize flow from different geometry
Axel B
B.Axel is on a distinguished road
Hello there,
I am currently doing simulations of a nozzle flow for my master's thesis with Fluent 18.2.
I want to create a steady state result for a particular mesh and BC setup (which I have already done) and then use this steady result to initialize a transient simulation in a nozzle with slightly different geometry, and subsequently different mesh.
I have tried to use the 'Interpolate' function in Fluent to initialize the flow and even though I don't recieve any errors, the flow is completely wrong, very patchy and coarse. It seems to import some sort of data, however, as some flow features can be found, altough with bad resolution.
Is it actually possible to interpolate data onto a different geometry, or is that feature only meant to be used for different meshes with the same geometry?
Thanks a lot in advance,
Axel
B.Axel is offline   Reply With Quote
Old   January 24, 2018, 13:27
Lucky
The interpolator does 0th order interpolation (it finds the nearest data) and that's why it gets really wonky on different geometry and even on the same geometry but different mesh.
If you want a better transfer, you would have to do the interpolation from the old grid onto the new grid yourself using some other tool. In my opinion Fluent would do well to at least smooth the data and do some laplacian blending or something (some sort of 1st order interpolation) but even that is not implemented yet (or maybe it has in the newer versions).
You are right, interpolate is meant for transferring data on different meshes within the same geometry. But of course this gives many people the idea to transfer data from one geometry to another. This was never the intent because in general, what logic do you use to assign values in the parts where the geometry is different?
Old   January 24, 2018, 14:15
Axel B
Thanks a lot for the response!
It's unfortunate that the initialization won't work as intended. I will try to find a workaround.
fluent, geometry, initialization, interpolate, mesh
Interfoam - Real world Geometry with constant inlet flow bdh1103 OpenFOAM Running, Solving & CFD 0 February 10, 2016 15:54
Geometry vs flow direction violetsaka Main CFD Forum 1 December 7, 2013 19:09
initialize flow field with steady state solution holg FLUENT 0 July 13, 2009 18:10
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
Is an uniform flow possible for this geometry? Michael Hu FLUENT 1 April 13, 2006 23:11
