Pressure Based Model (Scaled Residuals Convergence)
Old   January 19, 2018, 14:04
Default Pressure Based Model (Scaled Residuals Convergence)
Hells Blade
hellsblade.91 is on a distinguished road
Is it a golden thumb rule in Ansys Fluent ehat while using a pressure based model the residuals should awlays converge to 10^-6 ?
I am trying to simulate a flow of air at high pressures . I am using pressure based model my residuals dont converge upto the range of 10^-6 as mentioned in the fluent manual do i need to further dampen my resisuals . I am also getting reversed flow at my inlets and outlets
hellsblade.91 is offline   Reply With Quote
Old   January 23, 2018, 11:45
Refik
rewol is on a distinguished road
What is the operating pressure ?
Usually, for pressures more than 5 Mpa or temperatures lower than 200K fluid behaves non-ideally and you may want to use a real-gas model. If you are not solving energy equation, you can write UDF for density to achieve that.
Also, order of 1e-6 for residuals is just a rule of thumb and not the one and only criteria for convergence. You may want to check the mass flow entering and leaving your domain to see if they are sufficiently close.
As for your reverse flow, warnings should be removed as the iterations continue unless your mesh and initializations are proper for your case. I was able to get rid of reverse flow warnings when i provided a better mesh to my problem many times. (better does not necessarily mean "denser")
Try to initialize your flow field a bit better, close to final solution if possible.
Best of luck.
rewol is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Pressure based model and compressible flows sutthinan FLUENT 0 March 16, 2014 09:48
Pressure based vs density based solver newbie384 FLUENT 2 July 5, 2013 03:04
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
