January 18, 2018, 08:19 |
'Calculate' dialog box not responding
Clarice du Plessis
Rep Power: 9 |
Hi!
I am running a 2D LES simulation on V18.1. After initializing and running the simulation, the data files are written and "Done" is displayed. After that, the 'Calculate' dialog box is supposed to close, but it doesn't, and after a while, it displays "not responding". The program eventually has to be closed which means I am getting no results. This happens quite a lot but sometimes it doesn't, so I'm assuming the simulation is not the problem. When it happens, it doesn't matter how many iterations it's been run for; at the very end, it freezes. Has anyone else had this problem? If so, advice will be greatly appreciated! |
January 18, 2018, 08:45 |
Clarice du Plessis
Rep Power: 9 |
After months of struggling with the same problem, I find the solution 10 minutes after posting about it in the forum.
It seems like when I have contour plots, which I need to check between timesteps to ensure that the solution is correct, the 'calculate' dialog box freezes after the simulation. Must be a bug. |
January 18, 2018, 15:00 |
Lucky
Rep Power: 66 |
I've run into several mysterious bugs in Fluent when graphics are involved that tends to be machine specific and often very repeatable.
On one machine, when I tried to make filled contour plots would not be filled and show only the contour lines. However, if the contour would be filled if you pan the graphics window around but only while you are panning! Once you stop panning, the contour goes back to being weird again. Not sure what can be done to fix the issue because: what causes it? Probably there is a user settings file somewhere that is messed up. Have you tried a fresh install of Ansys or the VS C++ packages? |
calculate dialog box, dialog box not responding, fluent, fluent 18.1, not responding |
[General] calculating inside a box | nichbry3 | ParaView | 2 | May 10, 2017 07:46 |
[DesignModeler] simply model, empty box | conquer | ANSYS Meshing & Geometry | 0 | March 28, 2014 19:26 |
moving only one wall of box | raguelmoon | STAR-CCM+ | 7 | March 27, 2014 21:00 |
Junction Box | Anil | CFX | 2 | June 27, 2006 11:18 |
CFD for a Soap Box Derby car | Dean Christakis | Main CFD Forum | 0 | July 6, 1999 02:09 |
