polyhedral cells
Old   January 18, 2018, 06:14
Default polyhedral cells
Marcin
destroy is on a distinguished road
Hi everyone!
Is it possible to make polyhedral cells if I've got in some domains structural hexa mesh?
In this case I got below message, but I'm not sure if this is the reason.
Checking mesh..........
WARNING: left-handed faces detected on zone 23: 632910 right-handed, 64 left-handed.
Info: Used modified centroid in 622 cell(s) to prevent left-handed faces........
WARNING: The mesh contains high aspect ratio quadrilateral,
hexahedral, or polyhedral cells.
The default algorithm used to compute the wall
distance required by the turbulence models might
produce wrong results in these cells.
Please inspect the wall distance by displaying the
contours of the 'Cell Wall Distance' at the
boundaries. If you observe any irregularities we
recommend the use of an alternative algorithm to
correct the wall distance.
Please select /solve/initialize/repair-wall-distance
using the text user interface to switch to the
alternative algorithm.
Done.
WARNING: Mesh check failed.
WARNING: left-handed faces detected on zone 23: 448638 right-handed, 9 left-handed.
WARNING: left-handed faces detected on zone 23: 310860 right-handed, 45 left-handed.
WARNING: left-handed faces detected on zone 23: 549431 right-handed, 31 left-handed.
WARNING: left-handed faces detected on zone 23: 589341 right-handed, 134 left-handed.
WARNING: left-handed faces detected on zone 23: 617920 right-handed, 94 left-handed.
WARNING: left-handed faces detected on zone 23: 519310 right-handed, 34 left-handed.
WARNING: left-handed faces detected on zone 23: 569653 right-handed, 36 left-handed.
WARNING: left-handed faces detected on zone 23: 248809 right-handed, 7 left-handed.
WARNING: left-handed faces detected on zone 23: 303059 right-handed, 35 left-handed.
WARNING: left-handed faces detected on zone 23: 588350 right-handed, 11 left-handed.
WARNING: left-handed faces detected on zone 23: 212839 right-handed, 18 left-handed.
WARNING: left-handed faces detected on zone 23: 246950 right-handed, 20 left-handed.
WARNING: left-handed faces detected on zone 23: 270687 right-handed, 78 left-handed.
WARNING: left-handed faces detected on zone 23: 541047 right-handed, 9 left-handed.
WARNING: left-handed faces detected on zone 23: 617314 right-handed, 33 left-handed.
WARNING: left-handed faces detected on zone 23: 212600 right-handed, 139 left-handed.
WARNING: left-handed faces detected on zone 21: 8439 right-handed, 2 left-handed.
WARNING: left-handed faces detected on zone 30: 8439 right-handed, 2 left-handed.
WARNING: left-handed faces detected on zone 23: 206681 right-handed, 16 left-handed.
WARNING: left-handed faces detected on zone 23: 213164 right-handed, 16 left-handed.
WARNING: left-handed faces detected on zone 23: 187675 right-handed, 2 left-handed.
WARNING: left-handed faces detected on zone 23: 430473 right-handed, 14 left-handed.
WARNING: left-handed faces detected on zone 23: 176616 right-handed, 37 left-handed.
WARNING: left-handed faces detected on zone 23: 183367 right-handed, 64 left-handed.
WARNING: left-handed faces detected on zone 23: 265300 right-handed, 5 left-handed.
WARNING: left-handed faces detected on zone 23: 171339 right-handed, 50 left-handed.
WARNING: left-handed faces detected on zone 23: 197105 right-handed, 15 left-handed.
WARNING: left-handed faces detected on zone 23: 104299 right-handed, 21 left-handed.
To get more detailed information about the mesh check failure
increase the mesh check verbosity via the TUI command
/mesh/check-verbosity.
Fluent can also try to fix the mesh check problems via the TUI command
/mesh/repair-improve/repair.Warning:Frequency-of value for report-plot-0 is not valid. Associated report definitions will not be evaluated.
Regards
destroy is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
[ICEM] Problem with prism cells sidharath ANSYS Meshing & Geometry 0 September 1, 2015 08:09
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
polyhedral cells bill Main CFD Forum 10 March 11, 2014 07:52
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
