Hells Blade
Rep Power: 8 ![]() |
I am running a simulaion on fluent wherein i am trying to simulate a flow from the inlets to the outlet
Goal is to check no of inlets and pressure needed to get maximum pressure and velocity at the outlet. BC. Pressure Inlet - 6 bars Pressure Outlet Transient sim K-eplison model Attached are the contours showing the location of inlets and outlet and the mesh My doubt was how will my mesh cell size affect the no of time steps needed to run my sim Currently I am running my sim for a time step size of 0.001 with no of time steps of 10,000 Do i need larger no of time steps if i need run my sim for 20 s My fluid air in this case is at a high pressure 6 bars so I am using PISO( Pressure Coupled Solver ) as the flow would be unsteady will PISO be enough or do i run it on couped Will the gravity option also cause an intability in the resuts |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
[blockMesh] Flow domain by BLOCKMESH for plasma induced flow simulation | mukut | OpenFOAM Meshing & Mesh Conversion | 0 | June 2, 2014 06:19 |
Modeling the mixing of air and kerosene in a flow channel | StefanG | CFX | 3 | June 11, 2012 20:21 |
Modeling the flow domain in Icepak | saisanthoshm88 | ANSYS | 1 | December 12, 2011 00:20 |
