Multiphase Model or my own Udf code for membrane seperation process modelling
Old   January 16, 2018, 06:42
Question Multiphase Model or my own Udf code for membrane seperation process modelling
Sabrine BenSlama
Sabby is on a distinguished road
Hey, I'm working on a membrane seperation process (membrane distillation excatly) and i have to simulate the coupled heat and mass transfer through the membrane on ANSYS fluent .I'm new with fluent and
I'm wondering if i should use multiphase model or write my own udf !
Sabby is offline   Reply With Quote
Old   March 20, 2018, 11:17
zobekenobe
zobekenobe is on a distinguished road
It's best if you use a UDF to solve a User Defined Scalar equation for the transport at the membrane surface.
You can use the speigler kedem model or the solution diffusion model to be solved at the membrane for the flux.
I plan on using the multiphase DPM model, but haven't yet gotten around that. I'll update here in case I have any success. Presently I am using a UDF to calculate the flux through the membrane
zobekenobe is offline   Reply With Quote
Old   May 6, 2019, 06:40
Default Ion separation Membrane
Temidayo
techtradezone is on a distinguished road
Wow I am trying to solve the same kind of problem pls can I have access to the macro to use for this kind of operation... however, I intend to model ion exchange membrane
techtradezone is offline   Reply With Quote
Old   April 27, 2020, 03:33
Default UDF for mass transfer in membrane distillation
Rajeev Awasthi
rajeev2111 is on a distinguished road
I am new to the ANSYS as well as membrane separation modelling.
Can you please help me with how to write udf for mass transfer in FLuent??
I will be grateful to you.
Thanks
rajeev2111 is offline   Reply With Quote
membrane separation, multiphase model, udf code
Which Multiphase Model Should be selected in Fluent for my below described simulation oberstar Fluent Multiphase 0 September 28, 2017 13:05
Eulerian multiphase model for species trnasport: UDF for reaction rate harsh Main CFD Forum 3 June 12, 2017 03:24
How to simulate the eulerian multiphase model about particle jhlee9622 STAR-CCM+ 2 November 24, 2016 12:37
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
