Jinho Oh
Rep Power: 0 ![]() |
![]() ![]() I try to solve the pressure base and steady problem using fluent. However, in case of temperature difference, it is checked that the temperature is linearly distributed in the first iteration for fast convergence. Can i avoid this? Maybe I should change the configuration in the solver setting....and I need help. |
fluent, solver options, temperature |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Which solver required for humidity and temperature distributiion | Sandy7 | STAR-CCM+ | 2 | January 25, 2017 02:17 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
