January 4, 2018, 04:20 |
turbulent intensity for heat exchangers
soheil
Rep Power: 9 |
Hi All..
I want to model 7 rows of a heat exchanger. My B.C is velocity inlet and pressure outlet and two symmetric condition for up and down. In fluent guide said that turbulence intensity for heat exchangers is 5-20%. what should I exactly set my turbulent intensity at inlet and outlet. (Not that my Reynolds number at inlet B.C is 5000 and 100000 ..tow different cases) |
January 5, 2018, 06:10 |
Lucky
Rep Power: 66 |
Take your best guess or try them all and do a parametric sweep. Learn the sensitivity of the problem to the inlet turbulence intensity.
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Question regarding Reynolds Number and Turbulent Intensity | maxj | Main CFD Forum | 4 | March 5, 2013 07:16 |
k-epsilon: Defining turbulent intensity and length scale? | klausb | OpenFOAM | 0 | January 23, 2011 08:28 |
Turbulent intensity | swe704 | Main CFD Forum | 0 | November 13, 2009 04:42 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 01:05 |
