Phase Change of AdBlue (Thawing)
Old   January 3, 2018, 08:55
Default Phase Change of AdBlue (Thawing)
niewiemnic
spalartallmaras is on a distinguished road
I try to simulate the phase change of AdBlue from solid to liquid, but it is really hard to finish it.
There is a cylinder with 10 L and at the bottom of cylinder there is a heating mat with 60 W. In cylinder there is 4.5 L of frozen Adblue with -16 grad Celsius.
I turned on of cource VOF.
My question is,
1. Should be 3 phases-simulation(frozen Adblue, liquid Adblue, Air) or 2 phases-simulation(Adblue and Air)?
2. If I use 2 phases-simulation, how can I set the density of frozen Adblue and liquid adblue seperately? The Problem is, the density of frozen adblue has a constant value which is not depend on temperature and the density of liquid adblue is depend on temperature.
3. I also try to use 2 phases-simulation with Murnaghan equation of state for density. In this case the density of (frozen and liquid) Adblue is a value which has only a variable pressure. Should I use then UDF for the density?
Thank you very much!
spalartallmaras is offline   Reply With Quote
adblue, thawing
Multiphase solvers and non-isothermal phase change erlend_grotle OpenFOAM 1 September 25, 2021 10:48
Need help regarding phase change models in ansys fluent diggee Fluent Multiphase 0 October 11, 2016 12:35
Change phase phenomena Imane FLUENT 0 May 4, 2016 16:56
Pressure Outlet for phase change simulation dinesh FLUENT 0 November 22, 2013 00:50
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 04:59
