What type of model specific UDF needed for executing reduction process
Old   December 27, 2017, 07:15
Thumbs up What type of model specific UDF needed for executing reduction process
sooraj546 is on a distinguished road
There is a furnace in which a small porous layer exists at the bottom. Combustion is happening in the furnace and co co2 and temperature are developed which are used for the reduction process to happen in the botom porous layer and accordingly variation of co and co2 as well as temperature will come inside the furnace.
The reduction part inside the porous medium has to be incorporated as a UDF
UDF-EXPLANATION
Iron oxide reductions
3Fe2O3 + CO = 2Fe3O4 + CO2
Fe3O4 + CO = 3FeO + CO2
FeO + CO = Fe + CO2
carbon gasification (HIGHLY ENDOTHERMIC)
CO2 + C = 2CO
The reduction of iron ore coal composite pellet proceeds by the formation of the intermediate oxides evolution, which includes the following steps, i.e. hematite first gets converted to the magnetite then from there to wustite and finally iron and all these reduction happens by the regeneration of CO through carbon gasification equation
First order kinetics has been used for the reduction equation. details of rate eq is given n file attached.
R=(4*phi*r^2)exp(E/RT)(CONCco-(CONCco2/T)) for iron ore reduction, where CONCco is the concentration of co etc. like wise for carbon gasification as well.
i have written a udf using DEFINE_SOURCE but no variation in CO and CO2 concentration was observed.
What type of model specific UDF should be used for executing reduction process such that mutual interaction between combustion and radiation will be there inside the furnace.
like
DEFINE_VR_RATE
DEFINE_EXCHANGE_PROPERTY
DEFINE_SOURCE............itself
I AM TOTALLY CONFUSED.kindly help me out
sooraj546 is offline   Reply With Quote
Old   December 28, 2017, 08:39
kINDLY REPLY SOMEONE, its been a month ..............thanks in advance!
Old   January 1, 2018, 10:56
kINDLY REPLY SOMEONE..............thanks in advance!
Old   January 18, 2018, 02:51
Hello everyone
combustion model, fluent - udf, species transport model, udf and programming
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 03:41
Time step continuity error lpz_michele OpenFOAM Running, Solving & CFD 0 October 12, 2015 07:05
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
