December 18, 2017, 14:33 |
Mass flow rate
Hells Blade
Rep Power: 9 |
I am calculating the mass flow rate from 5 inlets when air flows to the bottom(outlet) however in fluent solution the graph of mass flow rate which we get i believe is mass flow rate flowing from each element is there a way to get a cumulative graph
From CFD Post I get a mass flow on outlet as -0.0647398 kg/s I am not sure if these value if completely justified with my simulation |
December 18, 2017, 14:38 |
Suraji
Rep Power: 10 |
Hello adas
I try to answer ur question The back flows maybe influence the mass flow outlet. And absolutely u used transient solver. U should considering the the back flow from each inlet. The boundary layers can be influence too. Thanks |
December 18, 2017, 14:50 |
Hells Blade
Rep Power: 9 |
Haidar thanks for your reply but how can the reverse flow at outlet be eliminated i am using pressure inlet and pressure outlet boundary condition and teh pressure is between 12-24 bars at inelt
December 18, 2017, 14:54 |
Suraji
Rep Power: 10 |
Trying to use velocity inlet and out mass flow. Reduce the roughness of wall
That u used pressure outlet u should input the pressure outlet. |
December 18, 2017, 14:59 |
Hells Blade
Rep Power: 9 |
I am simulating my flow with pressure inlet for diff pressures 12-24 bar the pich attached is 24 bar in velocity inlet boundary condition do i enter my total inlet pressure in outlow gauge pressure i dont think there is a way to define my pressure in pressure in velocity inlet BC
boundary condition with pressure AND mass flow rate | tsi07 | FLUENT | 3 | April 14, 2022 13:32 |
Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 4, 2016 00:08 |
trying to perform accurate mass flow rate sampling through hot-film probe | UTA_ARC | ANSYS | 0 | December 2, 2015 14:20 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 19:11 |
mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 11:44 |
