valve seat dynamic mesh
Old   December 15, 2017, 14:21
Default valve seat dynamic mesh
christoph45 is on a distinguished road
First of all: Hello everybody in this forum.
After learning to do some steady state analysis in Fluent I feel prepared to move in to my actual goal: dynamic meshes for an active valve simulation.
This ist my setup for learning mesh deformation:
(see attachment)
  • constant pressure inlet and outlet
  • valve-side + valve front are moving
  • valve speed actuated by udf DEFINE_CG_MOTION (prof-file works also)
I did my deforming mesh setup so far after this youtube tutorial:
  • smoothing only
  • valve-front: rigid body motion with udf or prof-file
  • valve-side: deforming with definition: cylinder
This works so far, but, of course, the mesh is not remeshed as no remeshing is set up. No matter what remeshing settings I try I always get a negative cell volume. So finally here's my question:
  1. What is wrong with my setup? Any suggesions?
  2. the next step I wanna try is to use the axis symmetry. What's the correct deforming mesh setup for the axis?
that's it so far...
I hope someone can help me.
Chris
christoph45 is offline   Reply With Quote
Old   April 18, 2018, 00:24
Kamal
soogeng is on a distinguished road
Hey there. did u manage to solve it? from what I can see it seems you are trying to "extrude" a wall into the domain.
I am having a similar problem but in my case I am trying to simulate a valve in IC engine.
soogeng is offline   Reply With Quote
Old   April 19, 2018, 03:04
Sorry, I switched to openfoam. Look for "enginefoam" and similar solvers.
Chris
deforming mesh, moving 2d meshes
Dynamic Mesh For a Poppet Valve irishguy FLUENT 0 January 11, 2016 15:46
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 09:00
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 09:01
