December 15, 2017, 04:09 |
Problem loading UDF in Linux environment
Harold Jankowski
Rep Power: 11 |
Hello everyone,
I am currently having a problem with Ansys Fluent on Linux. I want to run a simulation that contains a UDF for the drag function. Everything works flawlessly on Windows, but I need to simulate the bigger simulations on a Linux Server. Fluent itself starts without a problem, I have also already succesfully executed simulations without UDFs on the server. Loading the UDF into Fluent seems to be a bit of a problem, however. On Windows I always loaded the UDF via GUI which worked quite easily. As this doesn't seem to work on Linux I tried to follow the "Compile a UDF using the TUI" chapter from the UDF manual. However when I reach step 6, where it says I should type the fluent_arch command into the Linux console I get an error message saying: Unable to determine machine architecture. Set the environment variable FLUENT_ARCH and try again. Does anybody have a solution for this problem? Or is there an easier way to load a UDF into Fluent on a Linux system? I am using Fluent 17.2 Any help is greatly appreciated P.S I am not a Pro on Linux, since I started to work on the server just a few weeks ago. So, it would be great if you could explain any possible solutions in a way that also a noob like me can understand |
fluent, linux, udf |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 02:11 |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
problem in Loading UDF | achy7pch | FLUENT | 3 | January 11, 2010 18:56 |
UDF using problem, error happens-heip!! | Michael | FLUENT | 1 | December 9, 2008 07:51 |
parallel UDF problem | kerem | FLUENT | 2 | June 20, 2006 06:56 |
