Combustion Simulation ANSYS Fluent - There is no ignition delay
Old   December 14, 2017, 07:49
Default Combustion Simulation ANSYS Fluent - There is no ignition delay
Rudolf Diesel
Rudolf Diesel is on a distinguished road
I am trying a combustion simulation of diesel engine under the following settings.
I compared a pressure history between a simulation and a experimental.
However I don't get a agreement at the ignition delay period.
I tried to change some parameters,but i never get ignition delay from simulation.
How can i get a ignition delay from simulation?
Please help me.
Chemkin Input: Diesel_1comp_35sp_chem.inp(From tutorial)
Thermal Date File: Diesel_1comp_35sp_therm.dat(From tutorial)
Diesel Unsteady Flamelet Model
-Boundary Species
-O2: 0.231
-N2: 0.7575
-CO2: 0.0005
-H2O: 0.01
Injection Properties
-Material: Diesel liquid
-Diameter Distribution: uniform
-Diameter(m): 40.5e-6
-Temperature(k): 366.7K
-Cone Angle(deg): 6.52
-Cone Radius(m): 1.1e-4
-Total Flow Rate(kg/s): 1.065e-5
-Velocity Magnitude(m/s): 201.1
Initialization
-Gauge Pressure(pascal): 0
-Temperature(K): 300
-Turbulent Kinetic Energy(m2/s2): 0.025
-Turbulent Dissiption Rate(m2/s3): 0.0034
Rudolf Diesel is offline   Reply With Quote
Old   January 17, 2018, 11:51
adam
poutivar is on a distinguished road
Hi.
The ignition delay depends on the reaction mechanism you have...you should use one in the litterature that is well tested for diesel. I used to work with this one (29 species): here from The university of Wisconsin Madison.
I see you set the gauge pressure at 0.... It is the cylinder pressure ...take the intial value of pressure trace of your experiment.
Hope this helps.
Good luck.
poutivar is offline   Reply With Quote
Old   October 1, 2018, 02:16
Anil Bhaurao Wakale
anilwakale is on a distinguished road
Let me know the Species model you are using to find Ignition delay. I am using steady diffusion flamelet non-premixed combustion model (which is I guess wrong ). But we also have a problem of not getting ignition delay Instead as soon we insert droplet onto the chamber the combustion start. I am using DPM model for droplet combustion. We may gate Ignition delay from Diesel unsteady flamelet but the option will not appear until we ON the dynamic mesh option. We must discuss in details if you want
me12m1002@iith.ac.in is my email address
anilwakale is offline   Reply With Quote
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 21, 2017 00:47
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Melting Simulation by Ansys Fluent mohammad razzaghian FLUENT 0 July 25, 2014 18:37
Combustion SImulation in Fluent santhosh1987 FLUENT 1 May 14, 2010 17:03
Combustion SImulation in Fluent santhosh1987 FLUENT 0 May 14, 2010 11:32
