Combustion Simulation ANSYS Fluent - There is no ignition delay |
December 14, 2017, 07:48 |
Rudolf Diesel
Rep Power: 9 |
I am trying a combustion simulation of diesel engine under the following settings.
I compared a pressure history between a simulation and a experimental. However I don't get a agreement at the ignition delay period. I tried to change some parameters,but i never get ignition delay from simulation. https://www.dropbox.com/s/exmthra143...%20PM.png?dl=0 How can i get a ignition delay from simulation? Please help me. Chemkin Input: Diesel_1comp_35sp_chem.inp(From tutorial) Thermal Date File: Diesel_1comp_35sp_therm.dat(From tutorial) Diesel Unsteady Flamelet Model -Boundary Species -O2: 0.231 -N2: 0.7575 -CO2: 0.0005 -H2O: 0.01 Injection Properties -Material: Diesel liquid -Diameter Distribution: uniform -Diameter(m): 40.5e-6 -Temperature(k): 366.7K -Cone Angle(deg): 6.52 -Cone Radius(m): 1.1e-4 -Total Flow Rate(kg/s): 1.065e-5 -Velocity Magnitude(m/s): 201.1 Initialization -Gauge Pressure(pascal): 0 -Temperature(K): 300 -Turbulent Kinetic Energy(m2/s2): 0.025 -Turbulent Dissiption Rate(m2/s3): 0.0034 Last edited by Rudolf Diesel; December 14, 2017 at 12:32. |
May 21, 2023, 07:30 |
cfdarif
I am trying to learn analysis in ANSYS ICE for diesel engines. I am using version 18.2 myself. But I'm doing it from Tutorial 17.0. I also have the data of the tutorial, but;
1. Even though I do the mesh in the same way, it gives an error of ,1. 2. Fluent gets an error during the Fluent phase, and Fluent closes. Add species error. Do you have an ANSYS bibliography for the diesel engine? I would be glad if you help. Best regards, good work. cfdarif@gmail.com |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 21, 2017 00:47 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 01:17 |
Melting Simulation by Ansys Fluent | mohammad razzaghian | FLUENT | 0 | July 25, 2014 18:37 |
Combustion SImulation in Fluent | santhosh1987 | FLUENT | 1 | May 14, 2010 17:03 |
Combustion SImulation in Fluent | santhosh1987 | FLUENT | 0 | May 14, 2010 11:32 |
