Ansys Fluent Simulation Warning
Old   December 12, 2017, 11:12
Default Ansys Fluent Simulation Warning
Hells Blade
hellsblade.91 is on a distinguished road
Has anyone ever got such a warning in Fluent : LOW_DEG: Requires 2048 items per warp!!!
What does this interpret ?
hellsblade.91 is offline   Reply With Quote
Old   December 12, 2017, 22:33
GregCFD is on a distinguished road
I would guess it's a warning that the model you are using trying to run on your GPGPU has too few elements so it's either unable to run or will be very very inefficient.
This is based on:
LOW_DEG being a low degree of freedom warning, for a FVM formulation is ~the number of cells.
A warp is a Nvidia term (~equivalent to a Wavefront in AMD hardware) for the high level grouping of threads on the GPU, with the 2048 being the number of CUDA cores.
GregCFD is offline   Reply With Quote
Old   December 14, 2017, 05:19
Default Warning Ansys Fluent
Hells Blade
The simulation is running and my residuals look to be fine around e-6.
I just get this warning LOW_DEG: Requires 2048 items per warp initially in between some iterations and then its not there.
I am not sure how it affects my results
Old   December 14, 2017, 05:24
That's interesting, can you give us more details on your setup?, For example what kind of hardware your running it on and the setup of the simulation e.g Number of elements, Coupled or SIMPLE, Heat Equation on or off, Adaptive Meshing etc.
Old   December 18, 2017, 07:06
Hells Blade
My PC on which i locally run the simulns is basically 64 bit Professor , 64 Gb ram 4.20 Ghz
I am running a transient simuln where i am checking the mass flow rate and vel , pressure at my outlet when i have a pressure of 6-24 bar wiith varied no of inlets as in the pic attached (5 inlets in the pic)
I am running the sim on K-epslion Turbulent Model density based transient sim for approx 40 iteration upto 10 seconds
I am getting my results however I am not sure if these warning are affecting my results
GPU acceleration in Ansys Fluent flotus1 Hardware 63 May 12, 2023 03:48
How to use setField to create sphere sega OpenFOAM Pre-Processing 38 January 13, 2022 01:39
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
