Problem with conjugate heat transfer between 2 fluids |
Rep Power: 9 ![]() |
I a new to FLUENT -so kindly help me out.
PROBLEM WITH CONJUGATE HEAT TRANSFER BETWEEN 2 FLUIDS I have 3D-2 ZONE MODEL - a furnace part and a rectangular part inside it. Both are fluids but the the rectangular part is a porous MEDIUM. I combines the 2 parts (furnace part and a rectangular part) using form a new part in the geometry section- in order to get a good mesh continuity. Now in order to get heat transfer from the furnace part to the inside of the porous rectangular part what should the contact region between these two bodies be, should it be a 1. Interior furnace-rectangular which fluent automatically creates or 2. I should change it to wall and adjust the properties of the wall as such, as in wall case it becomes coupled and heat transfer is possible. 3. or like a solid-fluid interaction we should name the boundary wall in the furnace and rectangular section differently and combine it in mesh interface as coupled wall etc Kindly help me out- thanks in advance |
Kindly reply..............................!!!!!!!!!!! someone
Ravindra Shende
Rep Power: 15 ![]() |
Can you give some sketch of the geometry indicating the solid and fluid parts? (also indicate boundary conditions)
I have 3D-2 ZONE MODEL - a furnace part and a rectangular part inside it. Both are fluids but the bottom layer is the porous fluid layer. So what should be the contact region be .............by default interior will come etc. I combines the 2 parts (furnace part and a rectangular part) using form a new part in the geometry section- in order to get a good mesh continuity. Now in order to get heat transfer from the furnace part to the inside of the porous rectangular part what should the contact region between these two bodies be, should it be a 1. Interior furnace-rectangular which fluent automatically creates or 2. I should change it to wall and adjust the properties of the wall as such, as in wall case it becomes coupled and heat transfer is possible. 3. or like a solid-fluid interaction we should name the boundary wall in the furnace and rectangular section differently and combine it in mesh interface as coupled wall etc Kindly help me out- thanks in advance Last edited by sooraj546; December 7, 2017 at 13:40. |
Ravindra Shende
Ravindra Shende
I am assuming that there is no mass transfer between the two zones.
In that case you have to create two zones in the mesh separated by a surface. The mesh on the common surface should also be common for both zones. This will cause Fluent to recognize the mesh as two zones separated by a wall. Now you can use 'coupled' boundary condition a the common surface which will allow heat transfer between the two zones but no mass transfer. In the two zones you can set one zone as fluid and the other as porous. |
#9 |
There is mass transfer from zone 1 to the inside of the porous medium and back as well sorry I forgot to mention that , kindly reply . Thanks a lot in advance
But there is a problem if I do wall and coupled heat transfer is happening but sir wall is solid rt then mass transfer won’t work. So for this I have made 2 separate zone in geometry by frozen then formed new part then interior will come in between this 2 zones so mass transfer heat transfer can happen |
#10 |
Ravindra Shende
Fluent allows you to define a zone as porous. No need to specify any special boundary condition at the interface. Just specify the properties of the porous zone.
Here is the link: http://www.afs.enea.it/project/neptu...ug/node233.htm |
#11 |
so fluent is recognizing it an interior so what i am doing is absolutely fine ? and sir on more question..............................
sir- is mesh continuity important from zone one to porous zone for heat and mass trasnfer to happen? ----- even if mesh continuity is not there heat and mass transfer is happening...............so i am a bit confused .................kindly help? by mesh continuity i meant every nodes match at interface without any break |
#12 |
Ravindra Shende
Yes, what you are doing is fine.
I am not sure about mesh continuity thing. Is the mass transfer and heat transfer same in both the cases? |
#13 |
both case ?
#14 |
Ravindra Shende
#15 |
ok thanks a lot sir,
Apart from obtaining mesh continuity by forming a new part in geometry in fluent,,,,,,,,,,,,,,,,,, is there any other method for obtaining mesh continuity |
#16 |
sanjay sajeevan
Rep Power: 8 ![]() |
can you explain me how conjugate heat transfer can apply to a solid liquid interface please?
boundary condition, conjugate heat transfer, contact region, fluent, meshing 3d |
Conjugate heat transfer problem | troyker | FLUENT | 1 | March 22, 2014 13:46 |
Transient conjugate heat transfer problem | troyker | FLUENT | 0 | June 21, 2013 03:37 |
Hypersonic conjugate heat transfer problem | carnage2121 | FLUENT | 0 | June 4, 2011 18:08 |
Conjugate heat transfer problem | Soheyl | FLUENT | 2 | March 15, 2008 14:15 |
Heat Transfer problem (two different fluids) | Jon | FLUENT | 5 | February 20, 2008 06:56 |
