6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour
Old   December 5, 2017, 03:12
Default 6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour
Caster Troy
Caster_Troy is on a distinguished road
Hi everybody,
I'm trying to make a simple falling ball simulation in 2D domain using overset meshing. Here is the grid;
Initial Grid
Upper and lower ends of the background mesh are walls, left end is velocity inlet with 5 m/s of air inflow and right end is pressure outlet with 0 Pa gauge pressure. I obtained steady solution first and here is the velocity contours;
Initial (steady) velocity contours
And here is dynamic mesh settings;
Dyn. mesh settings
Two dyn. mesh zones:
1. Wall of the ball with passive disabled
2. Component zone of ball with passive enabled
After 38 time steps here is the velocity contours;
As you can see solver does weird things when dynamic mesh enabled. I calculates the velocity at wall as maximum, instead of applying no-slip condition. Any help is appreciated. Here is the UDF I used, I defined gravity internally;
#include "udf.h"
#include "math.h"
DEFINE_SDOF_PROPERTIES(Ball_free_fall, prop, dt, time, dtime)
       prop[SDOF_MASS] = 0.5;
       prop[SDOF_ZERO_TRANS_X] = FALSE;
       prop[SDOF_ZERO_TRANS_Y] = FALSE;
       prop[SDOF_ZERO_TRANS_Z] = TRUE;
       prop[SDOF_ZERO_ROT_X] = TRUE;
       prop[SDOF_ZERO_ROT_Y] = TRUE;
       prop[SDOF_ZERO_ROT_Z] = TRUE;
Caster_Troy is offline   Reply With Quote
Old   December 7, 2017, 07:19
Default sixdof
jingyuanli
beishannmuyu is on a distinguished road
Originally Posted by Caster_Troy View Post
Hi everybody,
Initial Grid
Dyn. mesh settings
#include "udf.h"
#include "math.h"
hi Caster
You know how to implement a sphere in the water rising at a constant speed?
beishannmuyu is offline   Reply With Quote
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent Qingsong FLUENT 2 March 21, 2022 16:08
FLUENT 6DOF dynamic mesh error pressure huhanghui FLUENT 0 September 20, 2017 08:16
Problem concerning FLUENT dynamic mesh fabian.g FLUENT 0 August 28, 2017 12:56
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Overset MESH problem DFBI 6DOF Ale85 STAR-CCM+ 0 October 1, 2013 13:25
