Meshing and Skewness
Old   November 27, 2017, 07:30
Default Meshing and Skewness
Hells Blade
hellsblade.91 is on a distinguished road
Hi
I want to check the air flow from my inlet(attached in the pic ) the 3 holes at the bottom represent my inlet approx 6 mm dia and at the top there is an opening which is the outlet . I basically need to see what difference would it make to the air flow when there are more inlets (3 or 5) or else the wall thickness is reduced in the current simuln it is 2 mm .
My question while meshing how much should i tarket my skewnes the currently value i am getting is 0.8-0.9 whereas 0.25 is generally taken for better results kindly give your inputs ?
hellsblade.91 is offline   Reply With Quote
Old   November 29, 2017, 06:58
Default About skewness and accuracy
Ovid
Fole is on a distinguished road
I think that value of skewness is ok, but I know that from user manuals, no my experience.
In fact, a skewed grid can give a good solution. It seems that there are no grid indexes for accuracy behorehand. Judgement can be donde after simulation. I started to read into the topic through the following weblink: https://blog.pointwise.com/2012/07/0...-mesh-quality/
Regards.
Fole is offline   Reply With Quote
Old   November 29, 2017, 10:03
Default reverse flwo pressure inlet
Hells Blade
Also my inlet is pressure inlet and outlet is mass flow outlet i am getting reverse flow on pressure inlet how can i rectify this
Old   November 29, 2017, 11:29
ehsan
e_cfd is on a distinguished road
I guess, since the pressure difference at the in/oulet is important, you can increase the pressure at the inlet to avoid the reverse flow.
By the way, why dont you change the inlet to mass flow BC and outlet to pressure outlet? Are there any special reasons?
e_cfd is offline   Reply With Quote
Old   November 29, 2017, 12:31
Hells Blade
Basically i am using the inlet as pressure inlet as i want the fluid to be at a certain pressure 6 bar also my mesh skewness is 0.71 at the moment could the mesh also be a reason
[ANSYS Meshing] Ansys meshing result very high skewness m5edr ANSYS Meshing & Geometry 18 February 3, 2020 12:35
[ANSYS Meshing] Fluent Meshing results in very high skewness FFD ANSYS Meshing & Geometry 10 August 31, 2017 12:09
Meshing - Skewness CPegg ANSYS 0 December 13, 2016 20:03
[ICEM] How can i reduce the skewness in this meshing??? gnut1989 ANSYS Meshing & Geometry 2 January 6, 2015 06:03
[Other] Cutcell meshing skewness RSaid ANSYS Meshing & Geometry 1 December 16, 2014 13:09
