Problem in parallel processing [Process affinity not being set] |
Rep Power: 8 ![]() |
Hey guys
I'm trying to do some parallel processing using Ansys fluent 18 but I have a problem. When I set processs to e.g. 35 I get this error: Code:
hp-reep is already loaded (92.9758%). Process affinity not being set. Code:
Host spawning Node 0 on machine "hp-reep" (win64). Host 0 -- ip 192.178.26.82 -- ranks 0 - 34 host | 0 ======|====== 0 : SHM Prot - All Intra-node communication is: SHM ------------------------------------------------------------------------------- ID Hostname Core O.S. PID Vendor ------------------------------------------------------------------------------- n34 hp-reep 35/2 Windows-x64 8968 Intel(R) Xeon(R) E5-2699 n33 hp-reep 34/2 Windows-x64 3396 Intel(R) Xeon(R) E5-2699 n32 hp-reep 33/2 Windows-x64 4968 Intel(R) Xeon(R) E5-2699 n31 hp-reep 32/2 Windows-x64 6080 Intel(R) Xeon(R) E5-2699 n30 hp-reep 31/2 Windows-x64 11000 Intel(R) Xeon(R) E5-2699 n29 hp-reep 30/2 Windows-x64 260 Intel(R) Xeon(R) E5-2699 n28 hp-reep 29/2 Windows-x64 4340 Intel(R) Xeon(R) E5-2699 n27 hp-reep 28/2 Windows-x64 3496 Intel(R) Xeon(R) E5-2699 n26 hp-reep 27/2 Windows-x64 11072 Intel(R) Xeon(R) E5-2699 n25 hp-reep 26/2 Windows-x64 480 Intel(R) Xeon(R) E5-2699 n24 hp-reep 25/2 Windows-x64 8740 Intel(R) Xeon(R) E5-2699 n23 hp-reep 24/2 Windows-x64 8704 Intel(R) Xeon(R) E5-2699 n22 hp-reep 23/2 Windows-x64 828 Intel(R) Xeon(R) E5-2699 n21 hp-reep 22/2 Windows-x64 5800 Intel(R) Xeon(R) E5-2699 n20 hp-reep 21/2 Windows-x64 8376 Intel(R) Xeon(R) E5-2699 n19 hp-reep 20/2 Windows-x64 8280 Intel(R) Xeon(R) E5-2699 n18 hp-reep 19/2 Windows-x64 8224 Intel(R) Xeon(R) E5-2699 n17 hp-reep 18/2 Windows-x64 6528 Intel(R) Xeon(R) E5-2699 n16 hp-reep 17/2 Windows-x64 8916 Intel(R) Xeon(R) E5-2699 n15 hp-reep 16/2 Windows-x64 8176 Intel(R) Xeon(R) E5-2699 ------------------------------------------------------------------------------- ID Hostname Core O.S. PID Vendor ------------------------------------------------------------------------------- n14 hp-reep 15/2 Windows-x64 8980 Intel(R) Xeon(R) E5-2699 n13 hp-reep 14/2 Windows-x64 1460 Intel(R) Xeon(R) E5-2699 n12 hp-reep 13/2 Windows-x64 9164 Intel(R) Xeon(R) E5-2699 n11 hp-reep 12/2 Windows-x64 9540 Intel(R) Xeon(R) E5-2699 n10 hp-reep 11/2 Windows-x64 9336 Intel(R) Xeon(R) E5-2699 n9 hp-reep 10/2 Windows-x64 4388 Intel(R) Xeon(R) E5-2699 n8 hp-reep 9/2 Windows-x64 5512 Intel(R) Xeon(R) E5-2699 n7 hp-reep 8/2 Windows-x64 6156 Intel(R) Xeon(R) E5-2699 n6 hp-reep 7/2 Windows-x64 8428 Intel(R) Xeon(R) E5-2699 n5 hp-reep 6/2 Windows-x64 10028 Intel(R) Xeon(R) E5-2699 n4 hp-reep 5/2 Windows-x64 9192 Intel(R) Xeon(R) E5-2699 n3 hp-reep 4/2 Windows-x64 9328 Intel(R) Xeon(R) E5-2699 n2 hp-reep 3/2 Windows-x64 9412 Intel(R) Xeon(R) E5-2699 n1 hp-reep 2/2 Windows-x64 9512 Intel(R) Xeon(R) E5-2699 n0* hp-reep 1/2 Windows-x64 8512 Intel(R) Xeon(R) E5-2699 host hp-reep Windows-x64 8316 Intel(R) Xeon(R) E5-2699 MPI Option Selected: ibmmpi Selected system interconnect: default ------------------------------------------------------------------------------- Cleanup script file is C:\Users\Administrator\Desktop\Aerospike-mesh-quad-1-2-new\cleanup-fluent-hp-reep-8316.bat > hp-reep is already loaded (92.9758%). Process affinity not being set. Reading "\"| gunzip -c \"C:\Users\Administrator\Desktop\Aerospike-mesh-quad-1-2-new\Aerospike_files\dp0\FLU-1\Fluent\SYS.1-Setup-Output.cas.gz\"\""... Buffering for file scan... 500500 quadrilateral cells, zone 3, binary. 995095 2D interior faces, zone 1, binary. 2804 2D interior faces, zone 2, binary. 2716 2D pressure-outlet faces, zone 6, binary. 100 2D velocity-inlet faces, zone 7, binary. 1680 2D wall faces, zone 8, binary. 1706 2D axis faces, zone 9, binary. 503602 nodes, binary. 503602 node flags, binary. Building... mesh auto partitioning mesh by Metis (fast), distributing mesh parts..................................., faces..................................., nodes..................................., cells..................................., bandwidth reduction using Reverse Cuthill-McKee: 14350/138 = 103.986 materials, interface, domains, mixture zones, axis wall inlet outlet surface_body interior-surface_body solid-surface_bodySetting solid-surface_body (mixture) ... Done. Setting zone id of solid-surface_body to 3. Setting zone id of interior-surface_body to 1. Setting zone id of surface_body to 2. Setting zone id of outlet to 6. Setting zone id of inlet to 7. Setting zone id of wall to 8. Setting zone id of axis to 9. Done. Setting solid-surface_body (mixture) ... Done. Setting inlet (mixture) (zone type changed to pressure-inlet) ... Done. Setting interior-surface_body (mixture) ... Done. Setting surface_body (mixture) ... Done. Setting outlet (mixture) ... Done. Setting wall (mixture) ... Done. Setting axis (mixture) ... Done. warning: for compressible (ideal and real) gas models with buoyancy, it is recommended to use a specified operating density value of zero. GUI access: Cell Zone/Boundary Conditions -> Operating Conditions... TUI access: define operating-conditions operating-density? parallel, Done. Preparing mesh for display... Done. Setting Post Processing and Surfaces information ... Done. By the way, when I run the calculation, it works as serial processing. I already ran calculation on this device for this project with parallel processing and everything was fine but now it doesn't work. What's the problem? Edit: just tried 2 procces and again got this error. |
Rep Power: 0 ![]() |
I've got the same problem
Replying only to get this post up |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
It is a warning message. It's a job scheduling problem and there's almost nothing you can do about it from inside Fluent. It basically means your cpu is busy doing other things and will not prioritize your Fluent processes. Fluent will be running in the background compared to whatever else is being done by your system.
What you can do, is stop running other programs. Figure out what is utilizing the cpu and shut it down, or run on a fewer number of available cores. This message is a hint: Code:
hostname is already loaded (##%). Last edited by LuckyTran; October 5, 2018 at 10:12. |
Thank you!
I suspected this should be the problem, but I needed someone who really knows this. I've read some thread about this, turned off hyperthreading as suggested and now barely got this message. |
#5 | |
Rep Power: 3 ![]() |
I use an Intel processor that has 24 physical cores. When I use the number of cores for example 14 or 16 or... in order to parallelize and reduce the solution time, my solution goes slowly. What should I do ? Thankyou |
Problem running OpenFOAM 2.2.x in parallel in Centos 5 | lvalvare | OpenFOAM Running, Solving & CFD | 33 | December 9, 2020 08:44 |
Temperature Problem in Parallel Processing | pdp.aero | SU2 | 9 | July 27, 2014 22:11 |
problem with parallel processing | keng | FLUENT | 4 | June 14, 2013 23:34 |
problem parallel processing (meshSearch, openMPI) | FabienF | OpenFOAM | 0 | September 10, 2012 04:23 |
About parallel processing in Linux | tuks | CFX | 10 | August 8, 2005 08:22 |
