How to find torque and angular velocity in Fluent?
Old   November 26, 2017, 08:11
Question How to find torque and angular velocity in Fluent?
Cheng ka kit
aacheng30 is on a distinguished road
I am doing a research on vertical axis turbine power generation under a specific wind velocity and I already simulate a model in fluent using 6dof. Like This
However, I don't know how to find the transient power generation. I come out with:P=FV
so I used the torque data generated in fluent and then divide it by the radius to find the F, but there are X,Y and Z axis of torque, so I am confused and I don't know which torque value I should use.
Also for the V, I consider using the default angular velocity expression in fluent to convert to linear velocity. However, the angular velocity is always zero under the omega expression.
Any one has any idea on my question?
Thanks
aacheng30 is offline   Reply With Quote
angular velocity, cfd - post, fluent, wind turbine
Time dependent angular velocity calculation UDF shashankmechguy Fluent UDF and Scheme Programming 1 July 26, 2018 03:23
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Angular Velocity (I know, I'm not the first one to ask!) Stabum CFX 4 October 31, 2016 03:47
UDF for time dependent angular velocity calculation shashankmechguy Fluent UDF and Scheme Programming 2 October 24, 2016 05:43
Angular velocity in wind turbine simulation vanni Main CFD Forum 1 May 18, 2009 12:03
