Why is outflow bc unsuitable for unsteady variable density flows? |
November 22, 2017, 15:10 |
A R Jensen
Rep Power: 8 |
I read in the Fluent manual that the outlflow boundary condition is unsuitable "if you are modeling unsteady flows with varying density, even if the flow is incompressible."
Is anyone able to explain or know why that is? |
November 22, 2017, 21:53 |
outflow bc is close to a fully developed condition, as the outflow boundary conditions assumes a zero streamwise gradient for all flow variables except pressure.
November 23, 2017, 04:03 |
A R Jensen
Rep Power: 8 |
Well even thought the flow is unsteady with varying density, can't the outflow not still have zero streamwise gradients for each time step?
boundary condition, fluent, outflow |
potentialFoam doesnt start?! | Sway | OpenFOAM Running, Solving & CFD | 0 | July 2, 2015 07:48 |
Density UDF for compressible liquid flows | KamilSobczak | Fluent UDF and Scheme Programming | 1 | July 15, 2010 07:32 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Low Mach number variable density | Mike | Main CFD Forum | 3 | February 25, 2003 14:54 |
variable density | Shigunov | Main CFD Forum | 7 | September 26, 1999 13:08 |
