Coating On the inner tube of counter flow heat exchanger
Old   November 22, 2017, 04:57
Question Coating On the inner tube of counter flow heat exchanger
Achyut
Achyut is on a distinguished road
I have a counter flow heat exchanger model with both outer and inner pipe as copper. The inner copper tube has a 1mm thick coating of tungsten carbide. Although I gave the coating there is not much change in the temperature difference between the hot fluid in the inlet and outlet. The cold and hot inlet temperature is given by the user and the results are hot and cold outlet temperature.
Uncoated Heat Exchanger
Cold in: 275K
Cold out: 308.34K
Hot in: 375K
hot out: 344.5K
Heat exchanger with inner tube coated
Cold in: 275K
Cold out: 308.14K
Hot in: 375K
hot out: 344.23K
What can be the possible cause?
Achyut is offline   Reply With Quote
Solidwork flow floefd - modeling heat exchanger in a system mzreik FloEFD, FloWorks & FloTHERM 3 January 8, 2016 12:30
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
heat transfer simulation of 3D laminar flow in uniformly heated tube engrmansoor2534 FLUENT 0 May 7, 2015 07:23
Modeling air flow through a heat exchanger dvanb STAR-CCM+ 1 May 15, 2014 21:54
shell and tube heat exchanger samidabest FLUENT 0 January 8, 2013 04:26
