Temperature does not change in Fluent simulation |
November 15, 2017, 07:39 |
Rep Power: 9 |
I'm trying to simulate the heat transfer through a coil. I'm setting the heat transfer coefficient to 100 W/mēK and using a delta T of 20 K, but the temperatures barely change (you can also notice that the energy residuals don't change). However, using CFX solver with the same conditions, I get reasonable results. Does anybody have any clue what could be wrong, please? Boundary conditions: Inlet: velocity - 2 m/sOutlet: gauge pressure - 0 PaWalls: no slip1.png residuals.png Fluent.jpg CFX.jpg Attached figures: 1 - Wall thermal B.C.; 2 - Fluent residuals; 3 - Fluent post-processing; 4 - CFX post-processing. Thanks in advance. |
November 15, 2017, 20:59 |
Alexander
Rep Power: 34 |
at inlet you have temperature - 298.15 K
at outlet temperature - 300 K Fluent is trying to find solution according to your BC. I have no idea why the temperature goes down in CFX, if you have the same BC there You may try to use outflow BC in outlet Best regards |
November 16, 2017, 11:36 |
#3 | |
Lucky
Rep Power: 66 |
It is a debugging problem I guess. Try using very stupid settings like 1000000 HTC. |
November 16, 2017, 11:57 |
Rep Power: 9 |
change, coil, heat, temperature, transfer |
Fluent phase change in a horizontal tube | eliastorca | FLUENT | 3 | January 26, 2024 22:49 |
Export granular temperature from fluent | langtou | FLUENT | 0 | July 23, 2017 08:27 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
An issue with temperature change in unsteady prob | Ashok kumar | FLUENT | 1 | January 13, 2009 05:34 |
